How to assign a variable to a string
Here is the example using arguments that assign a column property to a map role.
col<<Set Property( "Map Role", Map Role( Shape Name Use( "filepath to data table", "column name" ) ) );
I want to get the file path automatically and fill in to the "filepath to data table" in the arguments above.
And this is how I get the path of the file:
Logo_Name = Pick FIle();
Logo_Name_File = Open(Logo_Name);
LogoPath = Logo_Name_File << Get Path();
And below doesn't work for me.
:Measure points<<Set Property( "Map Role", Map Role( Shape Name Use( LogoPath , "Name" ) ) );
How can I fill in the "file path to data table " with the LogoPath variable?
Re: How to assign a variable to a string
 See if this works for you
Logo_Name = Pick File();
Logo_Name_File = Open( Logo_Name );
Eval(
	Substitute(
			Expr(
				:Measure points << Set Property( "Map Role", Map Role( Shape Name Use( __logop__, "Name" ) ) )
		Expr( __logop__ ), logoPath
Eval(
	Substitute(
			Expr(
Thank you so much! It works for me !
