CLC
CLC
How to apply same color themes to all graphs in contour plot function?
Dear sirs,
My JMP version is 16.2 pro.
Recently, I made some contour plot graphs by different conditions, and I wanted to apply all of them by same color theme (gradient funcition).
However, I could't find the method to apply them simultaneously.
I could only revise the color theme one by one graph.
Belows are my options list and gradient photo:
If someone has good idea, please don't hesitate to advise me.
Thierry_S
Re: How to apply same color themes to all graphs in contour plot function?
Have you considered applying an identical Color Gradient property to your data columns?
  1. Select all data columns
  2. Right-click on one of the column header
  3. Select Standardized Attributes
  4. In the interactive menu, Column Properties > Color Gradient
  5. Define the Color Theme, Minimum, Maximum, and Center
If this does not do the trick, you may want to explore scripting this operation with JSL.
Best,
TS
Thierry R. Sornasse
Thierry_S
NOTE: Sorry, this method does not apply to your specific question. I replied too quickly.
Thierry R. Sornasse
pauldeen
The only way I can think of is to do a little scripting, here is an example on big class:
Data Table( "Big Class" ):age << Set Modeling Type( "Continuous" );
cp = Contour Plot(
	SendToByGroup( {:sex == "F"} ),
	X( :height, :weight ),
	Y( :age ),
	Show Data Points( 1 ),
	Fill Areas( 1 ),
	Label Contours( 0 ),
	By( :sex ),
For( i = 1, i <= N Items( cp ), i++,
	cp[i] << SendToReport(
		Dispatch(
			OutlineBox(1),
			"1111",
			ScaleBox,
			{Legend Model(
				1,
				Type( 0, 262144, Item ID( "age", 1 ) ),
				Properties(
					0,
					{gradient( {Color Theme( "Blue to Gray to Red" )} )},
					Item ID( "age", 1 )
