  • We’re improving the Learn JMP page, and want your feedback! Take the survey
Bradley_Torres
How to adjust level text settings in plots?
Hi everyone,
I´ve been trying to adjust the text settings in my graphs (font size and type) of the X-Level and Y-Level names (Groups in the Graph Builder), but I haven´t been able to do so. I´ve tried even if change the font in the source Data Table, but it didn´t work. I wonder how could I do that. Thanks in advance.
frank_wang
回复: How to adjust level text settings in plots?
Hi
You can change The Font Size in Preference(Ctrl+K) --> Font --> Set Axis Title Font.
心若止水
6 REPLIES 6
frank_wang
Hi
心若止水
Bradley_Torres
Hi Mr Frank, thank you for your answer!!  I tried and it worked for axis titles (can also be modified directly in the graph builder). However, I wonder if it works for the text of axes level names (the ones which appear when you define them as the variables for X-groups and Y-groups in a plot). I´ve tried through the Preferences, but it seems there is no option available for axes level names.
TWE
TWE
Hi, I have the same question. Is there a solution in the meantime?
I think you have to change Text font to change those sizes. You can change them from preferences or with shortcut Ctrl+Shift and plus or minus depending on if you want to make text larger or smaller.
Remember to give kudos toRight-click to change Group font and font size
TWE
TWE
Thanks, thats it!
hogi
Level XII
Till Right-click to change Group font and font size   is available, you could try Graph Builder Toolbar:
It adds a shortcut icon to the Report Toolbar to cycle GroupX / Group Y / Wrap font size:
standard  large minimum
[quick and dirty via preferences settings]
