  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
EricTsai
How to add multiple reference lines to Y-axis in graph builder?
Hi All,
I came across some problems while using graph builder ,  I need to add different refrence lines to the Y-axis (like the attahced plot), which is catogorized into 4 groups.
but the defaut setting is that all groups apply to the same reference lines, could any one help to sovle this?
thanks in advance.
AndresGlez
Re: How to add multiple reference lines to each group on left Y-axis in graph builder?
Hi, I found this script previously in the community and save it becuse I need to create charts with different reference lines per group, hope this is also what you need.
NamesDefaultToHere(1);
// Different values for each group takes more work
gb2 = dt << Graph Builder(
Size( 534, 488 ),
Show Legend( 0 ),
Variables( X( :weight ), Y( :height ), Group X( :sex ) ),
Elements( Points( X, Y, Legend( 8 ) ), Smoother( X, Y, Legend( 9 ) ) )
gb2Rep = Report(gb2);
// Females . . .
gb2Rep[Framebox(1)] << addGraphicsScript(
PenColor("Orange"); HLine(60);
Transparency(0.25);
FillColor("Green");
Rect(50, 60, 180, 55, 1);
FillColor("Blue");
Rect(50, 65, 180, 60, 1);
// Males . . .
gb2Rep[Framebox(2)] << addGraphicsScript(
PenColor("Orange"); HLine(65);
Transparency(0.25);
FillColor("Green");
FillColor("Blue");
Rect(50, 70, 180, 65, 1);
This suggestion involves scripting but it is minimal.
  1. Right-click in one of the plots and select Customize.
  2. Click Add (plus sign).
  3. Type H Line( Y ), where the Y argument is the value for the reference line.
  4. Click OK
Repeat this process for each plot that requires a unique reference line.
Note that if you save a script now, it should include the customizations that you made.
Note that you can precede the graphic function with others to first determine attributes like color and line style.
12 REPLIES 12
Did you try it interactively and save the script?
EricTsai
Sorry, i dont know how to use JSL to add reference lines..
I did not say to use a script. I said interactively. Try right-clicking on one of these axes and select Axis Settings. Add the reference lines you want and click OK. If it only adds it to one of them, the right-click and select Edit > Copy Axis Settings. Hold the Control key, right-click on another axis, and select Edit > Paste Axis Settings.
Does either way work?
EricTsai
Yeah it works, But what i need is to add different ref. lines for each group,respectively. thanks !!
AndresGlez
Size( 534, 488 ),
Show Legend( 0 ),
// Females . . .
Transparency(0.25);
FillColor("Green");
FillColor("Blue");
// Males . . .
Transparency(0.25);
FillColor("Green");
FillColor("Blue");
EricTsai
thanks a lot , it helps~
  4. Click OK
EricTsai
GOT IT~ THANKS A LOT
Mark_W
This script is what I am looking for, but it assumes that the data in Framebox(1) is for the Female group. How could I test this to make sure that I was the lines to the correct Framebox?
