How to add columns with empty data
I have a table similar to this:
 xyz xyzxyz
aa12  .3
bb    ..
cc2 3 .5
The columns have rows containing both numeric and empty data.
I want to create a new column (xyz) where I add the data in column x, y and z.
In other words, I want the result to look like the green xyz-column.
The problem is, when I run my script, I get the result in the red xyz-column..
How do I add columns with empty data?
I use the following script to create the xyz-column:
dt << New Column("xyz",
         Numeric,
         Formula(:Name("x")+:Name("y")+:Name("z")
Re: How to add columns with empty data
Use:
dt << New Column( "xyz", Numeric, Formula( Sum( :x, :y,:z ) ) );
 The Sum() function ignores missing values.
Use:
Thank you, it works :)
