FN
FN
How to Visualize Survey Data with Multiple Responses Separated by ';' in Graph Builder?
I’m trying to visualize survey data in Graph Builder where the categorical column contains multiple selected options separated by ';', but I can’t figure out how to make JMP treat these as multiple responses.
How can I properly visualize this kind of data?
Example:
Q1 Q2 Q3
a;b a;c d
a;b;c;d b a;d
a;d a;b d
Re: How to Visualize Survey Data with Multiple Responses Separated by ';' in Graph Builder?
Have you tried setting those columns to multiple response columns WITH a separator (column property)?
Hi @FN ,
JMP doesn't work with multiple responses of ';' - I suspect it's because the ';' is used in the JSL script to mark the end of a command.
If you Find > Replace all to a comma (',') it will change to fit straight away.
Thanks,
Ben
