ramisola
How to Save Queried Data Table to a Specified Folder through script?
Hi! Does anyone here knows how to save a queried data table to a specified folder through jmp script? Can't seem to find the right way in doing it... Thanks in advance!
Here's my sample script:
Data Table( "name of data table" );
//save raw data table to a folder
dt = current data table ();
filepath = "C:\Users\folder path";
dt<< save(filepath || "name of data table.jmp");
Re: How to Save Queried Data Table to a Specified Folder through script?
I suspect the issue is that there is a "/" missing between your filepath and "name of data table.jmp".  Below is a working script that
Open( "$SAMPLE_DATA\big class.jmp" );
dt = Data Table( "big class" );
filepath = "$TEMP";
Wait( 5 ); // placed for the example so the table will be visible
dt << save( filepath || "\" || "mytable.jmp" );
Close( dt, nosave );
Wait( 5 );  // placed so for the example one can see the table is closed
Open( filepath || "\" || "mytable.jmp" );
Yes. Most of the time it seems to work better to keep a trailing slash on a path:
path = "$temp/mywork/";
Most (all?) functions that need just a path, without a file, are happy with it:
show(convertFilePath(path,"windows"));
Convert File Path(path, "windows") = "C:\Users\v1\AppData\Local\Temp\mywork\";
and it is clearly not a full filename to anyone looking at the code later.
