kachveder
How to Minimize data tables or put Data tables into a Tab Box, with the data tables created in a for loop
I am having some trouble with the following. I have a group of custom output, grouped by a variable, that I need to be in a single report. I get the output that I need. However, I get so many subset data tables as a result of the for loop. I was reading about tab windows, but there is not much written online about putting multiple data tables into tabs. Is there such an option?
If not, then perhaps I can add an option to my JMP script that automatically minimizes the data tables being generated with the report.
If there is no such option mentioned above, would there be a way to use only the select where statement to select the rows of the data and then use those rows to generate custom and automatic output into a single report? I tried to use this forum's methodology, but I wasn't getting any results.
Here is my current JMP script, along with the jmp file attached.
dt = Current Data Table();
col9 = Column(dt, "category");
unique_category = Associative Array(col9) << get keys;
nw= New Window("results",
    container = V List Box()
for (i = 1, i <= N Items(unique_category), i++,
	content = V List Box(
	vali = unique_category[i];
	dt << Select Where(:category == vali);
	//subset the selected data
	listDT = dt << Subset(
		output table name( "Subset where category is " || vali ),
		Selected rows only ( 1 ),
		Selected columns only( 1 )
	//Get the measurment units formatted, if applicable
	col4 = Column( listDT, "Measurement Units");
	units = col4[1];
	units_formatted = If(Is Missing(units), "", Is String(units), " (" || units || ") ");
	//chart
	Oneway(SendToByGroup( {:category == vali},
	Y( :results ) ),
	SendToByGroup(
			X( :name),
			Connect Means( 1 ),
			Grand Mean( 0 )
			SendToByGroup(
				Dispatch(
					"2",
					ScaleBox,
					{Label Row( Set Font Size( 5 ) )}
				Dispatch(
					"results",
					TextEditBox,
					{Set Text( vali || units_formatted )}
				Dispatch(
					"Oneway Plot",
					FrameBox,
					{Frame Size( 1500, 300 ), DispatchSeg(
						CustomStreamSeg( 6 ),
						{Line Color( "Gray" )}
					), Row Legend(
						subcategory,
						Color( 1 ),
						Color Theme( "" ),
						Marker( 0 ),
						Marker Theme( "" ),
						Continuous Scale( 0 ),
						Reverse Scale( 0 ),
						Excluded Rows( 0 )
	container << Append(content)
Re: How to Minimize data tables or put Data tables into a Tab Box, with the data tables created in a for loop
If you just make your subsetted data tables invisible, you can many times clean up your output.
listDT = dt << Subset( invisible,
kachveder
Thank you so much, Jim. That's exactly what I needed.
