agonzales2021
How to Hide Outline Box of Graph Builder
I would like to Hide the outline box that surrounds a graph builder.
I tried making it a report and deleting the Outline Box like
ybuild = Graph Builder();
yrep = ybuild << report;
yrep[ OutlineBox(1) ] << Delete;
The entire report just disappears.
Re: How to Hide Outline Box of Graph Builder
The graphic from the Graph Builder is nested underneath the outline box, therefore, if you delete the outline box, it will delete the graph.  Therefore, you need to move the graphic.  Below is a simple example of how to do that
dt = Open( "$SAMPLE_DATA\big class.jmp" );
gb = Graph Builder(
	Size( 519, 448 ),
	Variables( X( :age ), Y( :sex ) ),
	Elements( Points( X, Y, Legend( 5 ) ) )
Report( gb )[FrameBox( 1 )] << journal;
13 REPLIES 13
agonzales2021
gb = Graph Builder(
	Size( 519, 448 ),
agonzales2021
Hi Jim, thanks for your timely reply.. I'm trying it and I'm not seeing any kind of change.
Y_Graph = expr(
//For(k=1,k<=N Items(Act),k++,(
k=7;
ybuild = Yield_Tab << Graph Builder(
Size( 639, 378 ),
Show Footer( 0 ),
Lock Scales( 1 ),
Variables(
X( :Month ),
X( :WW ),
Y( Column(Act[k]) ),
Y( Column(Act[k]||" Weekly Target"), Position( 1 ) ),
Y( Column(Act[k]||" Month Target"), Position( 1 ) )
Relative Sizes( "X", [197 397] ),
Elements(
Position( 1, 1 ),
Line(
X,
Y( 1 ),
Y( 3 ),
Legend( 6 ),
Smoothness( 0.5 ),
Missing Values( "No Connection" )
Bar( X, Y( 1 ), Legend( 12 ), Label( "Label by Value" ) ),
Points(
X,
Y( 1 ),
Y( 3 ),
Legend( 16 ),
Jitter( 0 ),
Summary Statistic( "Mean" )
Elements(
Position( 2, 1 ),
Line( X, Y( 1 ), Y( 2 ), Legend( 7 ), Missing Values( "No Connection" ) ),
Bar( X, Y( 1 ), Legend( 13 ), Label( "Label by Value" ) ),
Points(
X,
Y( 1 ),
Y( 2 ),
Legend( 17 ),
Jitter( 0 ),
Dispatch(
"Month",
ScaleBox
Dispatch(
"WW",
ScaleBox
Dispatch(
Act[k],
ScaleBox,
{Min( eval(minl[k]) ), Max( eval(maxl[k]) ), Inc( 5 ), Minor Ticks( 1 ),
Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )}
Dispatch(
"400",
ScaleBox,
{Legend Model(
6,
Level Name( 0, "Yield" ),
Level Name( 1, "Ultimate Yield" ),
Properties(
1,
{Line Color( 20 ), Line Style( "Dotted" ),
gradient( {Scale Values( [0 1] ), Width( 9 ), N Labels( 6 )} )}
), Legend Model(
12,
Properties(
0,
{Fill Color( 2 ), Transparency( 0 ),
), Legend Model(
16,
Base( 0, 0, 0 ),
Base( 1, 0, 0 ),
Properties(
0,
{Line Color( 0 ), gradient(
Properties(
1,
), Legend Model(
7,
Base( 0, 0, 0 ),
Properties(
0,
{Line Color( 21 ), gradient(
Properties(
1,
), Legend Model(
13,
Properties(
0,
), Legend Model(
17,
Base( 0, 0, 0 ),
Base( 1, 0, 1 ),
Properties(
0,
Properties(
1,
{Scale Values( [0 1] ), N Labels( 6 )}
Dispatch( {}, "graph title", TextEditBox, {Set Text( Top_products[x]||" "||Act[k] )} ),
Dispatch( {}, "Y title", TextEditBox, {Set Text( Act[k] )} ),
Dispatch( {}, "X 1 title", TextEditBox, {Set Text( "Work Week" )} ),
Dispatch(
"400",
LegendBox,
{Set Title( "" ), Legend Position(
{6, [0, 1], 12, [-1], 16, [-1, -1], 7, [-1, -1], 13, [-1], 17, [-1,
-1]}
), Position( {0, 1, -1, -1, -1, -1, -1, -1, -1, -1} )}
Report( ybuild )[FrameBox( 1 )] << journal;
/ New Window( "Yield Dashboard",
Lineup Box(NCol(2), Y_Graph );
This script includes a lot of details that get in the way of testing a solution. I suggest you test your scheme to remove the outline box to work first with a simple example, then apply it to the real chart.
1. You need to read the Scripting Guide so that you understand how the Display Tree Structures work, which will allow you to interpret what the sample code I provided is doing.
2.  Below is a modification to the code that you provided.  In your example, what should have happened, is that a separate window should have appeared with the framebox from the Graph Builder in it, sans the outline box.  The new code places that frame box into the new window that you are creating.
Y_Graph = Expr(
	k = 7;
		Size( 639, 378 ),
		Show Footer( 0 ),
		Lock Scales( 1 ),
		Variables(
			X( :Month ),
			X( :WW ),
			Y( Column( Act[k] ) ),
			Y( Column( Act[k] || " Weekly Target" ), Position( 1 ) ),
			Y( Column( Act[k] || " Month Target" ), Position( 1 ) )
		Elements(
			Position( 1, 1 ),
			Line(
				X,
				Y( 1 ),
				Y( 3 ),
				Legend( 6 ),
				Smoothness( 0.5 ),
			Points( X, Y( 1 ), Y( 3 ), Legend( 16 ), Jitter( 0 ), Summary Statistic( "Mean" ) )
		Elements(
			Position( 2, 1 ),
			Points( X, Y( 1 ), Y( 2 ), Legend( 17 ), Jitter( 0 ), Summary Statistic( "Mean" ) )
			Dispatch( {}, "Month", ScaleBox ),
			Dispatch( {}, "WW", ScaleBox ),
			Dispatch(
				Act[k],
				ScaleBox,
				{Min( Eval( minl[k] ) ), Max( Eval( maxl[k] ) ), Inc( 5 ), Minor Ticks( 1 ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					6,
					Properties(
						1,
				), Legend Model(
					12,
					Properties(
						0,
				), Legend Model(
					16,
					Base( 0, 0, 0 ),
					Base( 1, 0, 0 ),
					Properties(
						0,
					Properties(
						1,
				), Legend Model(
					7,
					Base( 0, 0, 0 ),
					Properties(
						0,
					Properties(
						1,
				), Legend Model(
					13,
					Properties(
						0,
				), Legend Model(
					17,
					Base( 0, 0, 0 ),
					Base( 1, 0, 1 ),
					Properties(
						0,
					Properties(
						1,
						{Line Color( 0 ), gradient( {Scale Values( [0 1] ), N Labels( 6 )} )}
			Dispatch(
				"graph title",
				TextEditBox,
				{Set Text( Top_products[x] || " " || Act[k] )}
			Dispatch(
				"400",
				LegendBox,
					{6, [0, 1], 12, [-1], 16, [-1, -1], 7, [-1, -1], 13, [-1], 17, [-1, -1]}
	//Report( ybuild )[FrameBox( 1 )] << journal;
New Window( "Yield Dashboard", MyHLB = H List Box() );
MyHLB << append(Report( ybuild )[FrameBox( 1 )]);
Just a brief follow up to Jim's reply...
It isn't obvious when you look at a JMP window that the objects making up the window are nested. This branching structure leads to the name display tree. You can see the structure by right-clicking on the gray triangle to the left of the outline box and select Edit > Show Display Tree. You can delete any display box but it also removes any display boxes within.
Besides journaling, you can clone a display box (and its contents) and then include them in another window. Note that the cloning generally loses the interactivity of the original object, like journaling, but this way is another alternative to consider for your purpose.
XanGregg
Setting the outline title to empty will make it hide the top part.
ybuild = Graph Builder( ... );
yrep[ OutlineBox(1) ] << Set Title("");
Wow....another thing I knew at one time that I lost somewhere along the way.
Great post.....
pmroz
Similar to Xan's solution, in the graph-builder JSL you could do this:
dt = open("$sample_data\Big Class.jmp");
Graph Builder(
	Size( 526, 451 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 16 ) ), Line( X, Y, Legend( 18 ) ) ),
		Dispatch( {}, "Graph Builder",
			OutlineBox, {Set Title( "" )}
