BabyDoragon
How to Display Dynamic Variables in Bold within a Textbox
When using a Textbox, we can make words bold like the 'Test' text in the JSL below. However, if I want to display a dynamic variable in bold as well, how can I achieve that?
Variable = "Apple";
New Window( "test",
	Text Box( "<b>Test</b>", <<Markup ),
	Text Box( Variable ),
	Text Box( "<b>Variable</b>", <<Markup ),
Re: How to Display Dynamic Variables in Bold within a Textbox
The place to look for this information is the Scripting Index
     Help=>Scripting Index
It will give you all of the messages that can be given to the display object you are targeting(text box), along with it's description and examples of usage
For the whole text box you can do what can be found from scripting index (like Jim did show). You can also build the string with the variable evaluated to a string
strvar = "Apple";
nw = New Window( "test",
	Text Box(Eval Insert("no-bold <b>^strvar^</b> no-bold"), <<Markup)
strvar = "Apple";
