csoon1
How to Add Value Labels to a Column through JSL
On my main table (Table 1), I have a column called "Bin" which holds any number (corresponding to the column "Bin Number" entries on  another table which is Table 2). Now I want to assign Value Labels to this column "Bin" through script. The value labels would be coming from Table 2 with two columns: "Bin Number" and "Description".
Hard-coding something like
Column( dt, 1 ) << Add Column Properties( Value Labels( {"1" = "Cool", "2" = "Awesome", "3" = "Bad"} ), Use Value Labels( 1 ) );
is simple enough. However I am struggling with how to create the expression with the value labels being dynamic and formulated from whats on the other table. On the above code, "1, 2, 3,..." are entries for "Bin Number" while "Cool, Awesome, Bad,..." are entries for "Description" from Table 2.
I appreciate it if you can point me to some neat tricks. Thanks!
Re: How to Add Value Labels to a Column through JSL
Here is one way to handle the issue.  It basically creates a string that contains the specific structure needed.  Then add it as an element into the list required to be used to add the Value Labels to the column.
dt = New Table( "Untitled 36", Add Rows( 3 ),
	New Column( "Column 1", Character, "Nominal",
	Set Values( {"1", "2", "3"} ) ) );
NamesList = {"Cool", "Awsome", "Bad"};
ValuesList = Column( dt, 1 ) << get values;
NamesValuesList = {};
// Build the Value Labels List
For( i = 1, i <= N Items( NamesList ), i++,
	Insert Into( namesvalueslist,
		Parse( "\!"" || ValuesList[i] || "\!" = \!"" || NamesList[i] || "\!"" ) )
// Create the Value Labels
Column( dt, 1 ) << set property( "Value Labels", Eval( NamesValuesList ) );
csoon1
Thank you very much it worked. Your response made it look so easy.
