Luca23
How many sampes are needed -at least- to run nonparametric test
I'm assuming that 30 to 50 samples are required to run a  statisticaly sound test
MRB3855
Re: How many sampes are needed -at least- to run nonparametric test
Hi @Luca23 and welcome! Can you clarify/detail exactly what you are trying to do? The answer to your question, as you've proposed it, is "it depends".
