キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
Luca23
How many sampes are needed -at least- to run nonparametric test
I'm assuming that 30 to 50 samples are required to run a  statisticaly sound test
1件の返信1
MRB3855
Re: How many sampes are needed -at least- to run nonparametric test
Hi @Luca23 and welcome! Can you clarify/detail exactly what you are trying to do? The answer to your question, as you've proposed it, is "it depends".
おすすめの記事
