I am a new JMP Pro User with the following query. Using the Fit Model Standard Least Squares platform, I have 67 columns of continuous data. Each column has 213 rows. The 67 columns are entered as Y. Construct model effects adds another column containing five groups, each categorical. I am using this platform instead regular ANOVA to test interactions and other interactive effects. I find the scaled estimates to be highly informative. But exactly how is the scaled estimate calculated?
Thanks so much. JMP is fun.
rexneal
Jim,
Thanks so much
Check out the link above, it gives some indication of how a scaled estimate is calculated for a continuous variable.
No link. I must be obtuse. My question is how are scaled estimates calculated with a categorical variable?
The Scaled Estimates are only calculated for continuous model terms. An explanation of the method is described in the online documentation: Scaled Estimates and the Coding of Continuous Terms.
Categorical model terms are not scaled or otherwise affected by the "Scaled Estimates" option.
