M_Kraus
How is Std Error for Beta Binomial Distribution Analysis calculated? - differences between R and JMP
Hi All!
We are calculating beta binomial distribution parameters in R and wanted to compare the results and the std error.
Typically, the values for location and dispersion are up to 1% higher in JMP and there is also some discrepancy in the std error.
We would like to match here our R-code.
May anybody provide a hint how the standard error for mu and rho are calculated? Fisher Matrix?
Thanks
Re: How is Std Error for Beta Binomial Distribution Analysis calculated? - differences between R and JMP
JMP uses the inverse of the information matrix to estimate the covariance matrix (and standard errors). https://en.wikipedia.org/wiki/Fisher_information
Have you seen the JMP Help about this topic? Is it possible that the R function or model uses a different parameterization?
M_Kraus
I found this in your documentation:
Var(x) = np(1-p)[1+(n-1)δ]
Is this the Std Error shown in the table?
No, that quantity is the variance of the random variable when assuming a beta binomial distribution.
M_Kraus
Thank you very much. This is what I thought.
