docrossus
How does one perform Bitwise operations in JMP formulas?
Hi, I imagine this is simply an issue in which I am not finding the correct formula option but how does one perform basic bitwise operations in a JMP formula?
e.g. Here's an example Python example that I would like to replicate in JMP: lambda x: ((((x>>1)&0x1))<<2)
thanks, Ross
Re: How does one perform Bitwise operations in JMP formulas?
JMP has no native bitwise operators. In your example, I'd try this
// untested code for  (((x>>1)&0x1))<<2
f = function( { x },
    ( mod( floor( x / 2 ), 2 ) == 1 ) * 4
x>>1 (right shift 1) divides x by 2, &1 keeps only the least bit (zero/one, even/odd), and <<2 (left shift 2) multiplies by 4. (Assuming python works like C and I haven't forgotten...)
If you have a lot of these, with peculiar bit positions, etc, you might want to look for a bit manipulation library. The only one I'm aware of is in 7 things to know about Twitter and may not be very friendly (BITS.jsl file in the zip file). I don't remember exactly what it does, but it looks like it is solving the problem by turning a number into a character string of 32 ones and zeros, then combining the strings using AND/OR/etc logic rules. It is probably missing any operations that were not needed. And I'm pretty sure the HTTPRequest function would make that code much easier now.
Negative numbers can be really weird when doing right shifts. The sign bit can be trouble.
Level XII
hm ...
I added a request to the wishlist: JSL bit operations
(@jthi already requested in 2020)
For now, (Jmp18), what is the fastest way to extract the 32 bits of a 32bit number?
... for 10 mio rows?
n_rows = 100000;
dt = New Table( "test", Add Rows( n_rows ), New Column( "rand int", Set each value( Random Integer( 0, 4294967295 ) ) ) );
checkBit = Function( {x, bit},
	(Mod( Floor( x / 2 ^ (0 + bit) ), 2 ) == 1)
t0 = HP Time();
For( i = 1, i <= 32, i++,
	dt << New Column( "bit" || Char(i), Set each value( checkBit( :rand int, i ) ) )
Show( (HP Time() - t0) / 1000000 ); // references
//BITS:NUMTOBITS from https://community.jmp.com/t5/Uncharted/7-things-to-know-about-Twitter/ba-p/21000
// faster
getBits = Function( {x},
	{result = {}, i},
	For( i = 4294967296 / 2, i >= 1, i /= 2,
		Insert Into(
			result,
			If( x >= i,
				x = x - i;
				1;
				0
	Transpose(Matrix(result));
// ~ factor 10 faster
Transpose(Matrix(Transform Each({bit}, Words(Hex( x, Base( 2 ), Pad To( 32 ) ),""),Num(bit))));
//getBits(4294967295);
	New Column( "bit" || Char( i ) )
t0 = HP Time();
mat = J( n_rows, 32, 0 );
For( myrow = 1, myrow <= n_rows, myrow++,
	mat[myrow, 0] = getBits( :rand int[myrow] )
dt[0, N Cols( dt ) - 31 :: N Cols( dt )] = mat;
n_rows = 100000;
t0 = HP Time();
data = dt[0, 1];
	dt << New Column( "bit" || Char( i ) );
	dt[0,i + 1] = Mod( data, 2 );
	data = Floor( data / 2 );
This moves most of the looping into C++ code. If you can figure out how to do it with one divide, you might speed it up some more. You might want to use b0 rather than b1 for the least significant bit's name so its value is 2^0==1. Depends what the bits represent.
Level XII
wow, great
JMP Developers:
Please, please, please, please, please add bitwise operators to JSL.  Analyzing log files with bit fields (like error bits, status bits, etc.), I have had so many occasions to utilize bitwise operators.  This feature can also be extended by making user-defined bit mappings an option in the column properties (i.e. bit 0 = door open, bit1 = door closed, ...) and then in graph builder, plotting a single bit-mapped column variable against time, you could show all of the bit states flipping.
Level XII
hi @BetaTreeCamel91 , did you vote ?
JSL bit operations
