aumair
Convert a string to a list
Is there any builtin function to convert a string to a list? For example, I have a string "abcd1234cdef5678" and I want it to be converted to {"abcd", "1234", "cdef, "5678""}.
Thanks!
Ahmad
Re: Covert a string to a list
I am not aware of such a function, but you could use this code or make it a function
TheString = "abcd1234cdef5678";
TheList = {};
i = 1;
While( Substr( TheString, i, 4 ) != "",
Insert Into( TheList, Substr( TheString, i, 4 ) );
i = i + 4;
Or here it is as a function
SeparateString = Function( {TheString},
	TheList = {};
	i = 1;
		i = i + 4;
	TheList;
MyList = SeparateString("abcd1234cdef5678");
8 REPLIES 8
TheList = {};
i = 1;
i = i + 4;
	TheList = {};
	i = 1;
		i = i + 4;
	TheList;
aumair
Thanks a lot Jim!
RA899
Hi Jim,
 How would you approach this if you have a string, and a comma is where you want to stop separating the string.
For example,
converting this " C = "It is, raining, very, hard today" to b = {"It is" , "raining" , "very", "hard today" }
Thanks!
RA899
Update:
I have found an older thread about this from  Jeff_Perkinson.
This is the link Solved: Using several characters as delimiter for the Words function - JMP User Community
The solution that worked for me was using this method:
words(substitute("Test1eeTest2", "ee", "!"),"!")
{"Test1", "Test2"}
Thanks.
-Rakan
Use the Words() function to split the string into a List with the elements of the being each of the substrings identified by the specified delimiter, in your case a comma.
names default to here(1);
C = "It is, raining, very, hard today";
b = Words( C, "," );
Jeff_Perkinson
Take a look at the Words()  function. If you can define delimiters which separate the elements of the list then it will work for you.
-Jeff
Craige_Hales
Another technique:
parts = {};
rc = Pat Match( "1234567890abcdefghijklmnopqrstuv", Pat Repeat( Pat Len( 4 ) >> parts[N Items( parts ) + 1] ) );
Show( parts );
parts = {"1234", "5678", "90ab", "cdef", "ghij", "klmn", "opqr", "stuv"};
Jim's approach is better for short strings because the next person that maintains the JSL will understand it. For strings that are 10K or so, the pattern matching will be noticably faster.
The pattern match (red curve) avoids reprocessing the stringThe pattern match (red curve) avoids reprocessing the string
The is the JSL to make the graph...
dt = New Table( "Untitled",
	Add Rows( 0 ),
	New Column( "n", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
	New Column( "forloopTime", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
	New Column( "patternTime", Numeric, "Continuous", Format( "Best", 12 ), Set Selected, Set Values( [] ) )
For( nstr = 1, nstr < 10000, nstr *= 2,
	dt << addrows( 1 );
	dt:n = nstr * 4; // four substrings in the repeat...
	TheString = Repeat( "abcd1234cdef5678", nstr );
	start = Tick Seconds();
	TheList = {};
	i = 1;
		i = i + 4;
	stop = Tick Seconds();
	dt:forloopTime = (stop - start);
	parts = {};
	rc = Pat Match( theString, Pat Repeat( Pat Len( 4 ) >> parts[N Items( parts ) + 1] ) );
	dt:patternTime = (stop - start);
	Wait( 0 );
dt << Graph Builder(
	Size( 764, 624 ),
	Show Control Panel( 0 ),
	Legend Position( "Inside Left" ),
	Variables( X( :n ), Y( :forloopTime ), Y( :patternTime, Position( 1 ) ) ),
	Elements( Points( X, Y( 1 ), Y( 2 ), Legend( 9 ) ), Smoother( X, Y( 1 ), Y( 2 ), Legend( 10 ) ) ),
		Dispatch( {}, "n", ScaleBox, {Min( -1453.48837209302 )} ),
		Dispatch( {}, "forloopTime", ScaleBox, {Format( "Best", 12 ), Min( -0.949803149606299 )} ),
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "Compare algorithms" )} ),
		Dispatch( {}, "X title", TextEditBox, {Set Text( "n patterns " )} ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "Seconds" )} ),
		Dispatch( {}, "400", LegendBox, {Set Title( "" )} )
The reason the for loop example slows down on large strings: the substr function must find the location of each substring, starting from the beginning. The pattern match moves through the string once
Craige
bswedlove
If converting string to list of single characters (a little different from OP's request but matches the title) then can do:
Items( "hello", "" );
Which returns:
{"h", "e", "l", "l", "o"}
