lwx228
Level VIII
How do write code in JSL to call another JSL?
Hello everyone!
In  AAA.jsl, how do  write code that calls another JSL to continue running: for example, this another JSL is  BBB.jsl with the same path
When BBB. jsl finished, AAA. JSL continues to run the rest of the code.
thanks you!
6 REPLIES 6
Re: How do write code in JSL to call another JSL?
Use the
     Include();
function.
I strongly advise that you spend time and read the Scripting Guide
     Help==>Books==>Scripting Guide
lwx228
Level VIII
This seems to work,
where bbb. JSL only performs 2 files at a time, and moves the resulting file to another path in a timely manner, with code to clear the variable:
Include("d:\BBB.jsl");Wait(0);
Clear Log(); Clear Globals(); Close All(DataTables,"No Save");
This reduces the number of automatic exits.
lwx228
Level VIII
Please consult experts:
What else should you pay attention to in JSL, such as freeing memory and erasing variables?Thank you!
Except the following:Clear Log(); Clear Globals(); Close All(DataTables,"No Save");
Clear symbols();
gzmorgan0
Jim provided the correct answer, but this blog took another turn.
I recommend that you investigate scoping, specifically Names Default to Here() and New Context when working with Include();
Without proper scoping, clear symbols() could lead to unwarranted behavior.
You likely do not need this, but as an FYI, Run Program() can be used to create a new instance of JMP and execute a script or commands, then return to your session.  There is no sharing of data or variables.
lwx228
Level VIII
Well, Thanks for the way. I'll write them to BBB.jsl.
