取消
显示结果
显示  仅  | 搜索替代
您的意思是:
选择语言 隐藏翻译栏
AbbWorld27
How do i get the list box to work?
I am new to JMP and I came across the List Box which allows us to filter data based on the selection, but it is currently not working for me. I am getting the list box to display, but it doesn't change anything in the graph. I would expect the time to change based on arrival or departure.Any suggestions?
dt = Open("$sample_data/Air Traffic.jmp");
m_name = dt:Event << get values << As List(m_name);
gb_default = Expr(
	Graph Builder(
		Size(550, 372),
		Show Control Panel(0),
		Fit to Window("Off"),
		Variables(X(:Airline), Y(:Original Time)),
		Elements(Box Plot(X, Y, Legend(19)))
nw = New Window("Traffic Monitor ",
	gb = gb_default;
	lbcontent = Lineup Box(N Col(10),
		Spacer Box(Size(1, 0)),
		Text Box("Airline: ", <<Set Font Size(10)),
		List1 = List Box(m_name, nlines(3), width(50)),
		List1 << Set Items(m_name) << Get Selected
dk
6 条回复6
Re: How do i get the list box to work?
I would suggest using Local Data Filter for this instead of building list box with some custom jsl.
You can add local data filter from Toolbar
or red triangle menu
gb = dt << Graph Builder(
	Size(550, 406),
	Variables(X(:Airline), Y(:Original Time), Group X(:Event)),
	Elements(Box Plot(X, Y, Legend(19))),
	Local Data Filter(
		Add Filter(columns(:Event), Where(:Event == {"Arrive", "Depart"}))
AbbWorld27
Many thanks for this, this certainly helps! Would you know if it's possible to have local data filter positioned below the graph instead of on the left?
dk
I think you can do it at least by using Data Filter Context Box and data filter source box
nw = New Window("Selection Filter",
	Data Filter Context Box(
		V List Box(
				Size(550, 406),
			dfsb = Data Filter Source Box(
				dt << Data Filter(
					Local,
					Mode(Show(1), Include(1)),
AbbWorld27
Having some issues with both the local data filter & combo box fitting in. I am trying to build a tool for my company so I need the legend to be interactive, at the same time I want some to be able to put filters based on a column "season" in this example. But as I soon as I change the legend, the local data filter keeps expanding to down the graph. Would you know what I can do to improve this?
I've taken the animals data table as it's very small
dt = Open("$sample_data/Animals.jmp");
xlist = dt << Get Column Names( String );
gb_default = Expr(
Graph Builder(
Size( 544, 356 ),
Legend Position( "Bottom" ),
Fit to Window( "Off" ),
Variables( X( :species ), Y( :miles ), Color( :subject ) ),
Local Data Filter(
Add Filter(
columns( :season ),
Display( :season, Size( 160, 60 ), List Display )
Elements( Points( X, Y, Legend( 23 ) ) ),
Dispatch(
"400",
LegendBox,
{Orientation( "Horizontal" ), Sides( "Left" )}
gb_change = Expr(
Graph Builder(
Size( 544, 356 ),
Variables( X( :species ), Y( :miles ), Color( Column( dt, ycol )) ),
Local Data Filter(
Add Filter(
columns( :season ),
Dispatch(
"400",
LegendBox,
nw = New Window( "Animal test ",
gb = gb_default;
lbcontent = Lineup Box( N Col( 10 ),
Spacer Box( Size( 1, 0 ) ),
Text Box( "Color: ", <<Set Font Size( 10 ) ),
ycb = Combo Box(
xlist,
<<Set( 2 ),
<<Set Function(
Function( {},
ycol = ycb << Get;
gb << delete;
nw << Prepend( gb = gb_change );
dk
AbbWorld27
On the above, would you advise me to use data filters for both of them?
dk
When using the Data Filter, it should not be necessary to add the Data Filter Source Box().  Thought it does work on desktop JMP, it can affect other output such as to JMP Live.  The Data Filter Source Box should be added when you want to use a platform to filter one (or more) other platforms.  This modifies the script from @jthi  to demonstrate both.
nw = New Window("Filter examples",
	H List Box(
		Tab Page Box("Data Filter",
				V List Box(
						Size(550, 406),
					dt << Data Filter(
						Local,
		Tab Page Box("Selection Filter",
				V List Box(
						Size(550, 406),
							Size( 343, 132 ),
							Variables( Y( :Event ) ),
							Elements( Bar( Y, Legend( 2 ) ) )
推荐文章
