‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
GgGgGg2024
How do I write a function to display a column as a drop down list? The user should be able to select from this list
Re: How do I write a function to display a column as a drop down list? The user should be able to select from this list
If this is related to How do I get a list from an SQL query and let the user select the option from the list? you could have most likely kept discussion in that single topic. You have to options for drop-down, Combo box or button box
selections = {"One", "Two", "Three"};
nw = New Window("Example",
	H List Box(
		Panel Box("Combo Box",
			cb = Combo Box(selections)
		Panel Box("Button Box",
			btn = Button Box("Select", << Set Menu Items(selections))
Combo box is usually easier to use (Scripting Guide - Combo Box )
