How do I use user defined variables to define a database query?
Hello, I am using JMP16. I have a pop up box to ask for user input to define two variables ("Entity", and "Last_X_Days") that I would like to use to query a database. I have no problem getting these variables defined, but the data pull query is in quotations and wont take inputs as variables. It just takes them literally.
If "Last_X_Days" and "Entity" are previously defined as variables (based of the user input), how do I get the query to pull the variables and not just write literally the names of the variables?
Note: I changed some of the irrelevant code to more generic terms in CAPS.
Thank you!!!
script = PROGRAM:openDATABASEscript("\[
<PROGRAMInput>
  <Task>
    <TaskName>PROGRAM</TaskName>
    <AdditionalQueries>
      <Query>
        <TaskName>PARAMETER</TaskName>
        <AutoJoin>1</AutoJoin>
        <Parameters>TOOL</Parameters>
        <PrimaryEntity>1</PrimaryEntity>
      </Query>
    </AdditionalQueries>
    <AutoRun>1</AutoRun>
    <ExtractXML>1</ExtractXML>
    <Site>LOCATION</Site>
    <DATABASEQuery>
      <Query>
        <TaskName>DATABASEByDateRange</TaskName>
        <Parameters>PARAMETER NAME</Parameters>
        <Daterange>Last_X_Days</Daterange>
        <Entity>Entity</Entity>
        <ExcludeInvalid>0</ExcludeInvalid>
        <ExcludeNonstandard>0</ExcludeNonstandard>
        <ExcludePre>1</ExcludePre>
        <IncludeSubs>1</IncludeSubs>
        <MonitorType>ALL</MonitorType>
      </Query>
    </DATABASEQuery>
    <Technology>TECHNOLOGY</Technology>
    <ToolStyle>DATABASE</ToolStyle>
    <WriteJSL>FILE</WriteJSL>
  </Task>
</WijtInput>
Re: How do I use user defined variables to define a database query?
In this case I would most likely use Eval Insert()
Last_X_Days = 1;
Entity = "ABC";
query_template = "\[
<PROGRAMInput>
  <Task>
    <AdditionalQueries>
      <Query>
      </Query>
    <DATABASEQuery>
      <Query>
        <Daterange>¤Last_X_Days¤</Daterange>
        <Entity>Entity</¤Entity¤>
      </Query>
    </DATABASEQuery>
  </Task>
</WijtInput>
query_str = Eval Insert(query_template, "¤");
show(query_str);
script = PROGRAM:openDATABASEscript(query_str);
