rperkins
How do I use an if statement and a by variable correctly in a column mean formula?
I'm trying to use the columne mean formula to show the Time 0 average value for a columen of test samples, grouped by the test sample types.
I found this topic from 2012, that looked like it would work:
https://community.jmp.com/t5/Discussions/Determine-column-mean-by-day-and-within-certain-hours/m-p/5...
The recommended syntax there is:
Col Mean( If( 1 <= :Hour <= 10, :x, Empty() ), :Day )
However, when I try to use something similar with my data set, I get an "argument should be numeric 1 times at rows: 2" error.
This is the syntax I'm trying to use.
Col Mean(If( :DH hours == 0, :pm_mw, Empty() ), :Substrate)
I can get the forumla to execute correctly if I eliminate the by variable:
Col Mean(If( :DH hours == 0, :pm_mw, Empty() ))
Similarly, I can get it to evaluate correctly if I eliminate the I statement:
Col Mean(:pm_mw, :Substrate)
And finally, I can get it to evaluate correctly if all the values for DH hours in the table are 0. But if there are any non-0 values for DH hours in the table, it won't evalute.
Any suggestions would be appreciated.
Craige_Hales
Re: How do I use an if statement and a by variable correctly in a column mean formula?
Instead of empty(), use a missing value, represented by period.
formula column using ColMeanformula column using ColMean
Craige
Craige_Hales
Craige
rperkins
Thanks Craig. This worked.
