lala
Level VIII
How do I use Regex substitution?
Replaces the specified "(" with a newline character and removes all non-Chinese and non-numeric characters.
d试1(-是23(a文字789(+内c容4$3
txt="d试1(-是23(a文字789(+内c容4$3";
na=Regex(txt,  ?? );
12 REPLIES 12
lala
Level VIII
Re: How do I use Regex substitution?
Thank you so much Craige!
I know it's a very difficult job.Thank you for writing a general framework, I will try to learn more knowledge to modify.Thank you for your efforts.
lala
Level VIII
  • Like C# code coding code, how can you modify JSL?
  • I did not succeed in rewriting it.
h = [=> ];
u = "http://ds.m.emoney.cn/pick";
h["X-Protocol-Id"] = "8900";
h["X-Request-Id"] = "null";
b = Char To Blob( "~0A~0D~E5~BD~93~E6~97~A5~42~E7~82~B9~E8~82~A1~10~F2~DF~D2~09", "ascii~hex" );
rs = New HTTP Request( URL( u ), Method( "POST" ), JSON( b ), Headers( h ) );
rr = rs << Send;
lala
Level VIII
  • This is just the general outline.
  • The main problem is to solve how to write request parameters correctly in JSL.
