hogi
Level XIII
secretly open file
I have a script which scans a filename column in a Jmp data table and opens the respective files as Jmp data tables.
After 100 such files, my Jmp main window is crowded with measurement files and the important files get hard to find.
Is there an argument for open() which tells Jmp to forget that it opened the file
... such that the file doesn't get into the list on the main window?
Files which are opened in Batch mode via MFI don't get listed, right?
Re: secretly open file
Do you mean Recent files list? Add to Recent Files:
And if you mean window list, then opening them as Private should work (remember to close them and manage references properly in this case).
hogi
Level XIII
thank you.
Extremely nicely documented via the examples in the Scripting Index :)
I scanned the
and gave up too early ...
