According to the data of the "weight" column in document "Arrhythmia" 、and the "criterion" file in the attachment, the "level" column is obtained.
Then, according to the "level" column and "class" column, the data of "V3 QRSTA" column are classified according to the following rules:
Row basis is "level", column basis is "class", and positive value and negative value of "V3 QRSTA" column are classified and summarized respectively.
The above operations can be easily completed with excel and its functions, but the speed is slow when the data volume is large.
If the amount of data is large, how to use JMP JSL should be completed more quickly.Thank you very much!
This problem is quite complicated. I made several pictures and uploaded 2 files.
