Lavik17
How do I stack columns using a numerical range of columns in a script?
I know this is probably an easy one, but I've been struggling with this for the past 3 hours...
Using JSL, how do I stack columns using a numerical range? for example stack columns 3 to 16.
Thank you!!
Jasean
Re: How do I stack columns using a numerical range of columns in a script?
 You can use a matrix to specify the columns in the stack command.  Here is an example using a sample table:
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
StackDT = dt << Stack(
	columns( 5::10 ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	Drop All Other Columns( 1 )
Jasean
	columns( 5::10 ),
Lavik17
Thanks @Jasean !!!
