How do I selectively turn off parameters on the X-axis on different graph plots on the same graph
Jan 16, 2026 06:56 PM(2914 views)
I have 5 different plots that appear on the same graph using the same common X-axis for all 5 plots but I would like to selectively turn on and display only the parameters on the X-axis that are applicable (and turn off the rest that are not) to the respective plot. How do I do that?
