PG
PG
How do I perform row operations in looping?
I have a table like below.
A B C ..n columns
1 2 3
7 6 4
3 7 9
m rows
I want to write a script such that for every column " Value of nth row= Value of nth row -Value of 1st row" and in the end reset the first row to 0. So in the end my table should look like
A B C
0 0 0..
6 4 1
2 5 6
Could someone help me with a script for such an operation? Thanks
Re: How do I perform row operations in looping?
Here are a couple of ways to do the looping........more ways exist, but I will let others show them
// Open the data table
dt1 = Open( "$SAMPLE_DATA\Blood Pressure.jmp" );
// Create a second copy
dt2 = dt1 << subset( selected columns( 0 ), selected rows( 0 ) );
// Get all numeric, continuous column names
colList = dt1 << get column names( string, numeric, continuous );
// Loop across all numeric, continuous columns and use a
// matrix operation to handle the math
For( i = 1, i <= N Items( colList ), i++,
	mat = Column( dt1, colList[i] ) << get values;
	mat = mat - mat[1];
	Column( dt1, colList[i] ) << set values( mat );
// Now do the same thing looping with the data in place
	// Go through each row, from the bottom to the top to subtract
	// the value of the first row from each rows value
	For( k = N Rows( dt2 ), k >= 1, k--,
		Column( dt2, colList[i] )[k] = Column( dt2, colList[i] )[k] - Column( dt2, colList[i] )[1]
	mat = mat - mat[1];
PG
PG
Thanks txnelson. It works perfectly.
