Created:
Apr 6, 2021 03:29 PM
| Last Modified: Jun 8, 2023 2:03 PM(2188 views)
Hello, I was wondering if anyone else has had this problem. We have a DoE custom design for evaluating factors to optimize for product "B" over an impurity, "C." C isn't independent of B - it's a byproduct which forms only upon B forming, that is A -> B-> C. I see how in Column Info one can set independent limits for responses A and B, but is there a way to set constraints such that B + C < 100%? Thank you!
Not sure I understand completely, but here are my thoughts. Seems you Have A > B + C? In any case, you can add factors as mixture factors and impose linear constraints.
It sounds like both B and C are responses, rather than being controlled directly. If so, then would their measured values always be less than or equal to 100%? It seems like you might not need to introduce that constraint, and you could just try to maximize B and minimize C.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '374738' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '374738') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '374738') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
