JasonM
How do I model A -> B -> C behavior?
Hello, I was wondering if anyone else has had this problem. We have a DoE custom design for evaluating factors to optimize for product "B" over an impurity, "C." C isn't independent of B - it's a byproduct which forms only upon B forming, that is A -> B-> C. I see how in Column Info one can set independent limits for responses A and B, but is there a way to set constraints such that B + C < 100%? Thank you!
Re: How do I model A -> B -> C behavior?
Not sure I understand completely, but here are my thoughts.  Seems you Have A > B + C?  In any case, you can add factors as mixture factors and impose linear constraints.
ih
Super User (Alumni) ih
It sounds like both B and C are responses, rather than being controlled directly.  If so, then would their measured values always be less than or equal to 100%? It seems like you might not need to introduce that constraint, and you could just try to maximize B and minimize C.
