Snorfus
How do I hide and exclude different data for different graphs?
I'm hoping someone can help me.  I have a data set which I want to analyse in several different ways - this involves hiding and excluding data in one graph, but including it in another one.  I create one graph, with certain data hidden/excluded, save the script to the data table, then the next graph I create I change the data that is hidden/excluded and save the script.  When I go back to the first graph I have to re-hide/exclude the data to get the same results.  I dont want to split the data into different tables as that would mean updating multiple tables everytime I add new data.  Is there a way to link the data to the graph so I dodnt need to remember what data I hid/excluded for each graph?
Many thanks in advance!
Re: How do I hide and exclude different data for different graphs?
The approach you should use is to use a Local Data Filter directly on the graph you what to Hide and Exclude data. Click on the red triangle in the display output, and select Local Data Filter.
Snorfus
Just tried this and its perfect! Thank you!
