Bass_Masri
How do I have two different chart types in a single graph using two axis?
While doing some research to answer this question, I found this article on the JMP community that helped me get started. How do I do a combination bar and line plot using Overlay Plot?
Using the big class sample data example of height and weight I was able to create a bar chart for weight and a line plot for height on the same chart using the Overlay Plot.
To do this, first clear the row states in the JMP table. Create the overlay plot with the two variables, one on the left axis and one on the right axis.
Then go to the Red Triangle and click Show Control Panel.
Then select a point (for Height) and then right click and select Change to > Line
Then the circles for height change to a line.
Similarly select a point (for Weight) and then right click and select Change to > Bar
Then change the axis scale, legend location and colours to suit.
Final chart with x label for name.
Open("$SAMPLE_DATA/Big Class.jmp");
Graph Builder(
	Size( 793, 696 ),
	Show Control Panel( 0 ),
	Fit to Window( "Maintain Aspect Ratio" ),
	Variables(
		X( :name ),
		Y( :height, Side( "Right" ) ),
		Y( :weight, Position( 1 ) )
	Elements( Bar( X, Y( 2 ), Legend( 7 ) ), Line( X, Y( 1 ), Legend( 6 ) ) ),
		Dispatch(
			"height",
			ScaleBox,
			{Min( -0.268537964941355 ), Max( 71.08 ), Inc( 10 ), Minor Ticks( 0 )}
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				7,
				Properties( -1, {Marker( "Circle" )}, Item ID( "weight", 1 ) )
			), Legend Model(
				6,
				Properties( 0, {Line Color( 23 )}, Item ID( "Mean(height)", 1 ) ),
				Properties( -1, {Marker( "Circle" )}, Item ID( "height", 1 ) )
		Dispatch(
			"400",
			LegendBox,
			{Legend Position( {7, [1], 6, [0]} ), Position( {1, 0} )}
Bass Masri
BSc.(Math) MStat.
0 REPLIES 0
