Bradley_Torres
How do I get upper error bars only in a X-Y plot?
Please, anyone knows how to show upper error bars only in X-Y plots? Thanks in advance
Re: How do I get upper error bars only in a X-Y plot?
I can't replicate issue you are having as I don't know your data or how you are plotting it (which zones are being used for example). I'm using JMP18 and I can get the upper errorbars work in many different ways
Right click on the graph, select customize, find error bars and change interval sides
Bradley_Torres
Thanks so much! However, when trying this with "upper" option, the error bars are displaced above the mean point (like figure below) , and what I really want is to stay on the point, showing upper bar only. Do you know please how to get it? And thanks again
What type of error bars are you trying to apply? to what type of data?
Bradley_Torres
Hi.  I just have time profile for different subjects , and the plots takes calculates mean and Std Dev (for each of the 3 lines) . But I just want to show the upper bar only, but when trying what you suggested me , it displaces the bar instead of keeping upper half only
