How do I get tolerance interval for regression line?
How can I obtain the tolerance interval for my regression model in JMP? I have already obtained the confidence interval and prediction interval, but I am unsure of how to calculate the tolerance interval. Any guidance on this matter would be greatly appreciated.
MRB3855
Re: How do I get tolerance interval for regression line?
Good question. There are, however, no easy (point and click) answers so you will have to code it up yourself.. It is a research topic and if you google it you will find lots of stuff out there. This article may not be a bad place to start.
https://juniv.edu/journal/11397/file
