Auto Click Button
Hi Guys,
How I can auto click button "OK" after I choose variable , because after this dialog I have to run another chart and data
You can see in below pictures
cwillden
Re: Auto Click Button
Can you elaborate on under which conditions you would want to automatically click "OK"?  In JSL, you can programatically click a button using something like "OK_button << click;"
If, for example, you want to programatically click OK once all required inputs are populated, you could write a function or expression like this:
check_inputs = Expr(
	If(
		N Items( y_inputs << get items ) > 0 & N Items( x_inputs << get items ) > 0
		 & N Items( parts_inputs << get items ) > 0,
		OK_button << click
Then, within  the script for each of the input buttons, you could add check_inputs() at the end.
-- Cameron Willden
Thank you so much, I will try it on my script
TDF
TDF
How can you find out what the button is called?
I have a similar issue with the GO button needing to be automatically pressed.
I've guessed (presumably incorrectly) at what it might be called but those combos GO_button, etc. did not work.
The previous example uses a variable GO-button in which a reference to an actual button was previously stored. See the example below for the basic approach to use.
Names Default to Here( 1 );
// example data set
// example dialog
launch = dt << Fit Model(
	Y( :weight ),
	Effects( :age, :sex, :height ),
	Personality( "Standard Least Squares" )
// find Run button and unwrap the list
button = (launch << XPath( "//ButtonBox[text()='Run']" ))[1];
// click it!
button << Click;
