BookmarkSubscribeRSS Feed
lwx228
Not applicable
Aug 14, 2018
How do I exit the loop when something is satisfied?
After the data table is sorted by the age column in ascending order, the cycle is conducted by the age column. When the age is equal to the age of the previous row, n=n+1, otherwise, the cycle is withdrawn.Thank you!
dt = Open( "$SAMPLE_DATA\Big class.jmp" );
r = N Row( dt );
n = 0;
For( i == 2, i <= r, i++,
If( dt[i - 1, "age"] = dt[i, "age"],
n = n + 1,
stop loop
pmroz
Jun 23, 2011
Solution
Re: How do I exit the loop when something is satisfied?
You want the BREAK command.  From the scripting index:
For( i = 1, i <= 10, i++,
	If( i == 5, Break() );
	Print( "i=" || Char( i ) );
pmroz
Jun 23, 2011
Solution
