How do I create a new table using another columns?(get columns from different tables)
dt1 = Open( "$SAMPLE_DATA/Iris.jmp" );
New Table( "Merge Columns",
	Add columns( 3 ),
	Add rows(100),
	New Column( "1st",
		Set Values( column(dt, 3 ) )
	New Column( "2nd",
		Set Values( column(dt, 1) )
	New Column( "3rd",
		Set Values( column(dt1, 1) )
Hi all.
I want to make a new table getting another columns by different tables.
How can I do that?
Re: How do I create a new table using another columns?(get columns from different tables)
Join is most likely the best option (match by row number if you don't have any column to use).
Then delete extra rows you don't need
