acm
acm
How do I create a counting variable based on another column & transpose a table?
Hi all,
I'd appreciate help with reformatting a clinical dataset. It records ~50 variables for multiple patients on multiple visits. So there are ~51 columns with one being an MRN or record number per patient. There are typically 6-7 rows of data per patient/MRN to report on variables taken at different visits. So 2 questions:
1)How can I generate a new incremental count variable that counts number of visits per patient MRN and resets to 0 if the MRN changes in another column?
2)Using this new count variable (and/or the MRN variable), how can I transpose the data so that I have 50x 7 variables in columns for each patient, with each patient now being a single row? Ex: if patient had weight and temp recorded for 7 visits, can I do multiple columns for weight1, weight 2, weight3,...weight7 and similarly for temp1, temp2...temp7?
Thx for the advice in advance!
MRN.   Date of Visit.  Ideal Counter (based on MRN change)
1001.   01/23/2020.     1
1001.   01/30/2020.     2
1001.   02/04/2020.     3
1001.   12/02/2015.     4
1001.   12/09/2015.     5
1001.   12/16/2015.     6
1001.   12/23/2015.     7
2350.   01/06/2016.     1
2350.   04/14/2016.     2
2350.   12/17/2018.     3
2350.   12/21/2018.     4
2350.   12/31/2018.     5
2350.   01/07/2019.     6
2350.   01/14/2019.     7
2311.   02/17/2016.     1
2311.   03/02/2016.     2
2311.   03/16/2016.     3
2311.   07/18/2016.     4
2311.   07/25/2016.     5
2311.   08/01/2016.     6
2311.   08/08/2016.     7
11223. 08/15/2016.     1
11223. 08/22/2016.     2
MarkJSchwab
Re: How do I create a counting variable based on another column & transpose a table?
The formula for your counter column is just Col Rank(:DateOfVisit, :MRN).
Then the pivot is Tables -> Split -> Split By: Counter; Split Columns: Height, Weight; Group: MRN
