You can use "Move Selected Columns()" to move a column that you have added to the end of your data table.  However, just as with the "Add Multiple Columns" the choices are focused on adding after a column.  So you would have to subtract 1 from your position, and then use that value as the insert position
dt << New Column("The New Column", set selected)
Wait( 2 );
dt << Move Selected Columns( after(as column(1)) );
// or
dt << Add Multiple Columns( "Added ", 2, after(as column(1)), numeric );
