ReginaHong
JSL script if statement then Delete Column
I am new to JSL script. How do I write in JSL script for the scenario below:
If  last 10 rows in column A <= to last 10 rows in column B, then delete column C and column E else delete column D and column F. The values in the last 10 rows within columns A & B are always the same. Can anyone help to translate this into JSL script?
Re: JSL script if statement then Delete Column
If I am interpreting your request properly, the following simple script will give you what you want
dt = Current Data Table();
// Initialize a counter
count = 0;
// Loop through the last 10 rows and count
// the number of times :A<=:B
For( i = N Rows( dt ) - 9, i <= N Rows( dt ),
	i++,
	If( :A[i] <= :B[i], count++ )
// Handle the 2 scenarios for which columns to delete
If( count == 10,
	dt << delete columns( {"C", "E"} ),
	dt << delete columns( {"D", "F"} )
count = 0;
	i++,
If( count == 10,
