john_madden
How do I combine tables
I have two tables, A and B. I want to write JSL that will find all the rows in A whose ID is represented one or more times in B, and then append those rows to B to yield a new table C.
For example, let this be A:
ID
Data
Day
1
Red
Sun
2
Orange
Mon
2
Yellow
Tue
3
Blue
Wed
4
Indigo
Thu
4
Violet
Fri
4
Fuchsia
Sat
5
Teal
Sun
6
Black
Mon
And let this be B:
ID
Data
Day
6
Aqua
Tue
1
Pink
Wed
1
Beige
Thu
4
White
Fri
9
Gold
Sat
10
Silver
Sun
I want code to generate a table C that looks like this (row order doesn't matter):
ID
Data
Day
6
Aqua
Tue
1
Pink
Wed
1
Beige
Thu
4
White
Fri
9
Gold
Sat
10
Silver
Sun
1
Red
Sun
4
Indigo
Thu
4
Violet
Fri
4
Fuchsia
Sat
6
Black
Mon
This seems simple, but I've confused myself as to the best way to do it. The method should scale well with respect to speed and memory for A and B tables of >1 million rows.
cwillden
Re: How do I combine tables
I think this should be relatively computationally efficient, and you can don't have to do it exactly this way.  Basic idea is to create a table that is a subset of the Table A where the IDs are also in Table B.  Then concatenate the subset of A to Table B.
dtA = Data Table("Table A");
dtB = Data Table("Table B");
b.ID = dtB:ID << Get Values;
b_ID_unique = associative array(b.ID) << Get Keys;
dtA << Select Where(Contains(b_ID_unique,:ID) > 0);
dtASelected = dtA << Subset( Selected Rows );
dtB << Concatenate(
dtASelected,
Output Table( "Table C" )
Close(dtASelected, No Save);
Other approach might be to hide and exclude the data that doesn't match the criteria.  This eliminates the need to create a subset table, but the hidden and excluded data come along with the concatenation.  You could select the hidden and excluded rows and delete them, but that might not be a very robust solution if you have other rows hidden and excluded that you wouldn't want to delete.
Third option is make a column formula indicating if row in A has an ID that exists in B, then delete the resulting rows in C that aren't a match based on the values in that column.
I'm sure there are numerous other ways to skin this cat, but hopefully this will do the trick.
-- Cameron Willden
Here is a Join centric version of a script that will work....it should be pretty efficient
names default to here(1);
dtA = data table("A");
dtB = data table("B");
// Create data tables with only the data required
dtAID = dtA << Subset(invisible, selected rows(0), columns(:ID));
dtBID = dtB << Subset(invisible, selected rows(0), columns(:ID));
// Create a data table with only IDs found in both tables
dtABID = dtAID << Join(invisible, with(dtBID ),
	Merge Same Name Columns,
	By Matching Columns( :ID = :ID ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 0, 0 ),
	Preserve main table order( 1 )
close( dtAID, nosave );
close( dtBID, nosave );
// Create a table with only 1 row for each ID found
dtSum = dtABID << Summary(invisible,
	Group( :ID ),
	Freq( "None" ),
	Weight( "None" )
// Create a data table that only has the correct IDs
// from data table A
dtAMatches = dtA << Join(invisible,
	with(dtSum ),
close( dtSum, nosave );
// Delete column Match Flag and N Rows
dtAMatches << delete columns("Match Flag", "N Rows");
// Concatenate table B with the matched data from table A
dtFinal = dtB << Concatenate( dtAMatches );
close( dtAMatches, nosave );
cwillden
dtB << Concatenate(
dtASelected,
-- Cameron Willden
	Group( :ID ),
	Freq( "None" ),
	Weight( "None" )
	with(dtSum ),
john_madden
The associative array option is quite neat and I haven't used this concept very much, and never as a kind of alternative to a join. The option using the join is great to see because that was the approach that I was trying to work out for myself, but got confused.
I'm grateful to both of you for confirming that while relatively simple, this doesn't have a "one-step" or unique solution.
Thanks to both of you!
John
john_madden
I'm grateful to both of you for confirming that while relatively straightforward, this doesn't have a "one-step" or unique solution.
John
