Shan
Actual by predicted plot
Hi
I'm relatively new to JMP.
When I run a Fit Model, why sometimes I don't see a Actual by predicted plot? I still see other things such as Effect Summary, Parameter Estimates..
Thanks.
Re: Actual by predicted plot
It might be due to a change in the Emphasis selection. JMP has a decision tree that tries to determine the most useful Emphasis setting (initial report). All information is available regardless of the choice for Emphasis. It is simply a matter the initial report.
I believe that other aspects of the analysis can affect what is reported initially, but I don't know the details!
Shan
I found the answer myself. I should click the rew triangle and then then Row Diagnostics.. Sorry for the post.
