RogerBui
How do I check the kind of distribution of a sample data?
Hi everybody,
Could you please have me a clue to check a kind of distribution of a sample data set by JSL (Ex: check to see if a sample data has normal distribution or not?
Thanks.
Re: How do I check the kind of distribution of a sample data?
Here is the example from:
     Help==>Scripting Index==>Distribution==>Continuous Distribution==>All
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = Distribution( Column( :CO ) );
obj << Fit Distribution( All( 1 ) );
I assume by your question that the user is not directly involved (interactive assessment) but instead a hypothesis test is desired. I would employ the Distribution platform. Launch it with the data column to be tested in the Y role. Fit the normal distribution and obtain the results of the goodness of fit test. Illustrated with the weight variable in the sample data table Big Class:
dist = dt << Distribution(
	Y( :weight ),
	Fit Distribution( Normal( Goodness of Fit( 1 ) ) )
dist rep = dist << Report;
p value = dist rep["Goodness-of-Fit Test"][NumberColBox("Prob<W")] << Get( 1 );
Hope answer helps.
	Y( :weight ),
Hope answer helps.
