ac11ca
How do I change the title of my figure in chart builder?
Thanks,
Adrian
pmroz
Re: How do I change the title of my figure in chart builder?
Once you click "Done" you can edit the title.
9 REPLIES 9
pmroz
In graph builder just double click on the title and type away.  Using Graph > Chart you would do something similar - double click on the word "Chart" next to the red triangle.
ac11ca
That doesnt seem to be working for me. Double (or tripple) clicking on the title just highlight the title. I cant edit it. Screenshot below.
pmroz
ac11ca
Thanks!
And how do you change the font size of the axis titles (e.g, in my attached "Number of Outcomes") and labels without changing default preferences in the JMP File/Preferences menu?
Cheers,
Adrian
pmroz
Double-click on the desired axis and you'll get a dialog box that allows you to change most things, including the font size and labels.
ac11ca
Thanks - this allows me to change the font size of the axis numbers, but not the title?
pmroz
Click directly on the title and you can change it.
ac11ca
When I click on the axis title I can change the words but not the font size?
peterj
The following will allow you to change the font size of the x and y labels. I don't know how to change the legend font size though, it doesn't work the same way.
Open("$SAMPLE_DATA\Big Class.jmp");
Graph Builder(
    Variables( X( :height ), Y( :age ) ),
    Elements( Points( X, Y, Legend( 1 ), Jitter( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
    SendToReport( Dispatch( {}, "X title", TextEditBox, {Set Font Size( 20 )} ), ),
    SendToReport( Dispatch( {}, "Y title", TextEditBox, {Set Font Size( 20 )} ), )
