How do I change the Graph Frame box Outline color and add a box around legend?
Apr 10, 2025 05:11 PM(1649 views)
Hello! I am trying to make the top and right border on the attached graph black and size 2 to make it publication quality. I am able to toggle it on and off using Right click -> Graph -> Border though. I checked the properties as well and I am unable to see a option to change it.
Additionally, I want to put a outline around the Legend frame box if possible? Thanks!
> I assume border follows same "numbering" as Border Box
I would suggest using <<Border(1) rather than <<Border(15). The general Border property works like Padding and Margin, except that currently only 1-pixel borders are currently supported. If that were to change, a setting of 15 might be a bit surprising!
You can also explicitly use <<Border(Left(1), Top(1), Right(1), Bottom(1)) to make it more clear. When a single value is used, it applies to all sides.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '867603' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '867603') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '867603') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
