Teena
How do I apply different tests to a g-chart (rare event attribute) control chart
Hello
Does anyone know how to rules other than outside limits in a g-chart (i.e a test for six (or more) points in a row continually increasing (or decreasing)).
I've tried using the preferences/platform/control charts options but not sure why it's not applying.
Any suggestions much appreciated.
(I'm using #JMPpro16 and very new to scripting so if the only way is to script I might need some really basic hints!)
Re: How do I apply different tests to a g-chart (rare event attribute) control chart
As you have discovered, the only test JMP allows for rare event charts is test beyond limits.  You would need to write a script for any additional tests.  Unfortunately, I do not have any sample code to share for doing this.
Teena
Thank you for confirming that I hadn't missed something obvious and indeed will work towards writing some script.
Any additional tests depend on the nature of the response (continuous or categorical) and the distribution of the response. For example. Nelson developed a set of 8 tests for common (but not exhaustive) special causes when using the Individuals Chart (X-chart) for continuous and normally distributed data.
You might be able to use this description (see page 1192)  from SAS documentation to implement appropriate tests for the G-chart in JMP.
Teena
Thank you for the link - very useful!
