clarencelew
How do I add a filter column as a AND criteria
The syntax for Add Filter dictates that the new columns must be in the OR criteria.
Is there some way I can add rules in an iterative way?
dtf<<Add Filter(columns(column <,col>), <Where(clause)>)
Add one or more filter columns in a new OR group.
11 REPLIES 11
ian_jmp
Level X
Re: How do I add a filter column as a AND criteria
Here's one way:
// AND
df << removeLocalDataFilter;
colList = {"age", "sex"};
CMD =
Expr(
	df = gb << Local Data Filter(
		Add Filter( columns( colsTBD ) )
SubstituteInto(CMD, Expr(colsTBD), colList);
CMD;
newbie_alex
I fail to understand the fundamental difference between
1)
df = gb << Local Data Filter(Add Filter(columns({"age", "sex", "name"})));
and
2)
colList = {"age", "sex", "name"};
df = gb << Local Data Filter(Add Filter(columns(colList)));
1) works and 2) does not.
Would you please explain WHY?
Thank you for your help!
