lwx228
Level VIII
How can open a datatable with JSL and run a script in that datatable?
For example, open "Big class.jMP" and run the "Distribution" script.
Re: How can open a datatable with JSL and run a script in that datatable?
The method I use to find out such question is
  1. Open the Scripting Index
  2. Since I (you) want to run a script from a data table, type in the search field, "Script"
  3. Look through the options it displays to see if any of them might be what you need
  4. Click on ones that might be what you want and check out the description and example(s)
