How can i overlay standard deviations onto a histogram?
Mar 2, 2016 08:56 AM(25070 views)
I'm trying to overlay a normal distribution with standard deviations from the mean onto a histogram. Attached as an example of something similar to what I'd like to create.
You could interactvely follow the instructions in the accepted solution for a particular case. Save the script from the platform with the results you want. Modify the script to extract the sample statistics estimates and then substitute them into the expressions for the reference region parameters. That approach seems reasonable.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '17279' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '17279') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '17279') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
