See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
How can filter all data in a category whose minimum value is greater than the specified value in a specified column?
lwx228
Level VIII
For example, in "Big Class. JMP ", all data of minimum body "weight" greater than 80 in each age group are selected by "age" column?For JSL
Re: How can filter all data in a category whose minimum value is greater than the specified value in a specified column?
If I understand what you are asking...….you should be able to figure this out yourself
dt=current data table();
dt << select where(col min(:weight,:age) >80);
lwx228
Level VIII
Thank Jim!
Is this SQL syntax?
SQL does have "Select" and "Where" components of it's language, what I provided to you is a
     Select Where()
function right out of JSL
No recommendations found
